GASP: from Modular Programming to Distributed Execution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
We present in this paper a generic animation and simulation platform which integrates the different animation models: descriptive, generative and behavioural models. The integration of these models in the same platform allows to offer to each dynamic entity a more realistic and a richer environment, and thereby to increase possible interactions between an actor and its environment. Therefore we describe the kernel of the platform, then we explain how it is used from the programmer point of view and we illustrate its use in the field of driving simulation.
articleIEEECA98.pdf (135.9 Ko) Télécharger le fichier
inria-00534149 , version 1 (12-11-2010)
  • HAL Id : inria-00534149 , version 1
Stéphane Donikian, Alain Chauffaut, Thierry Duval, Richard Kulpa. GASP: from Modular Programming to Distributed Execution. Computer Animation 1998, 1998, Philadelphie, United States. ⟨inria-00534149⟩
99 Consultations
238 Téléchargements
