Querying Unranked Trees with Stepwise Tree Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
The problem of selecting nodes in unranked trees is the most basic querying problem for XML. We propose stepwise tree automata for querying unranked trees. Stepwise tree automata can express the same monadic queries as monadic Datalog and monadic second-order logic. We prove this result by reduction to the ranked case, via a new systematic correspondence that relates unranked and ranked queries.
Automatique
stepwise.pdf (178.24 Ko) Télécharger le fichier
inria-00536529 , version 1 (16-11-2010)
  • HAL Id : inria-00536529 , version 1
Julien Carme, Joachim Niehren, Marc Tommasi. Querying Unranked Trees with Stepwise Tree Automata. 19th International Conference on Rewriting Techniques and Applications, 2004, Aachen, Georgia. pp.105--118. ⟨inria-00536529⟩
147 Consultations
313 Téléchargements
