Well-Nested Parallelism Constraints for Ellipsis Resolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
The Constraint Language for Lambda Structures (CLLS) is an expressive tree description language. It provides a uniform framework for underspecified semantics, covering scope, ellipsis, and anaphora. Efficient algorithms exist for the sublanguage that models scope. But so far no terminating algorithm exists for sublanguages that model ellipsis. We introduce well-nested parallelism constraints and show that they solve this problem.
wellnested.pdf (126.51 Ko) Télécharger le fichier
inria-00536541 , version 1 (16-11-2010)
  • HAL Id : inria-00536541 , version 1
Katrin Erk, Joachim Niehren. Well-Nested Parallelism Constraints for Ellipsis Resolution. 10th Conference of the European Chapter of the Association for Computational Linguistics, Association for Compuational Linguistics, 2003, Budapest, Hungary. pp.115--122. ⟨inria-00536541⟩
92 Consultations
160 Téléchargements
