Parallel Model Checking for Temporal Epistemic Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Marta Kwiatkowska
  • Fonction : Auteur
  • PersonId : 861066
Hongyang Qu
  • Fonction : Auteur
We investigate the problem of the verification of multiagent systems by means of parallel algorithms. We present algorithms for CTLK, a logic combining branching time temporal logic with epistemic modalities. We report on an implementation of these algorithms and present the experimental results obtained. The results point to a significant speed-up in the verification step.
ECAI-112.pdf (114.3 Ko) Télécharger le fichier
inria-00536670 , version 1 (16-11-2010)
  • HAL Id : inria-00536670 , version 1
Marta Kwiatkowska, Alessio Lomuscio, Hongyang Qu. Parallel Model Checking for Temporal Epistemic Logic. European Conference on Artificial Intelligence, Aug 2010, Lisbon, Portugal. ⟨inria-00536670⟩
Collections
CONNECT
74 Consultations
95 Téléchargements
