Underspecified Beta Reduction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
For ambiguous sentences, traditional semantics construction produces large numbers of higher-order formulas, which must then be beta-reduced individually. Underspecified versions can produce compact descriptions of all readings, but it is not known how to perform beta reduction on these descriptions. We show how to do this using beta reduction constraints in the constraint language for lambda-structures (CLLS).
usp-beta.pdf (118.15 Ko) Télécharger le fichier
inria-00536805 , version 1 (16-11-2010)
  • HAL Id : inria-00536805 , version 1
Manuel Bodirsky, Katrin Erk, Alexander Koller, Joachim Niehren. Underspecified Beta Reduction. 39th Annual Meeting of the Association for Computational Linguistics, 2001, Toulouse, France. pp.74-81. ⟨inria-00536805⟩
27 Consultations
86 Téléchargements
