Wing shape optimization using FFD and twist parameterization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Optimization of wing shapes for aerodynamic performance is presented using a combination of particle swarm method and surrogate models. The wing shape deformations are parameterized using free form deformation together with wing twist. The developed strategy is applied to the lift-constrained drag minimization of Onera M6 wing.
Paper_for_AeSI_2010.pdf (767.18 Ko) Télécharger le fichier
inria-00537316 , version 1 (18-11-2010)
  • HAL Id : inria-00537316 , version 1
D. Chauhan, Praveen Chandrashekarappa, Régis Duvigneau. Wing shape optimization using FFD and twist parameterization. 12th Aerospace Society of India CFD Symposium, Aug 2010, Bangalore, India. ⟨inria-00537316⟩
325 Consultations
754 Téléchargements
