Uncertainty Quantification for Robust Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
The objective of this chapter is to present, analyze and compare some practical methods that could be used in engineering to quantify uncertainty, for mechanical systems governed by partial differential equations. Most applications refer to aerodynamics, but the methods described in this chapter can be applied easily to other disciplines, such as structural mechanics.
chapter_uncertainty.pdf (782.13 Ko) Télécharger le fichier
inria-00537339 , version 1 (18-11-2010)
  • HAL Id : inria-00537339 , version 1
Régis Duvigneau, Massimiliano Martinelli, Praveen Chandrashekarappa. Uncertainty Quantification for Robust Design. Piotr Breitkopf and Rajan Filomeno Coelho. Multidisciplinary Design Optimization in Computational Mechanics, ISTE - Wiley, 2010. ⟨inria-00537339⟩
219 Consultations
517 Téléchargements
