Sweepers & Swirling-sweepers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
Alexis Angelidis
  • Fonction : Auteur
  • PersonId : 861167
Sweepers and swirling-sweepers are operations for modeling by space deformation. The artist describes a deformation as paths through which tools are moved. The movement of a tool causes a deformation of the working shape along the path of the tool. This is in accordance with a clay modeling metaphor, easy to understand and predict. It is desirable that deformations for modeling are `foldover-free', that is parts of deformed space cannot overlap so that the deformations are reversible. Both sweepers and swirling-sweepers satisfy this criteria. In addition, swirling-sweepers preserve the shape's volume.
eg05_angelidis-1.pdf (10.55 Mo) Télécharger le fichier
inria-00537449 , version 1 (25-11-2010)
  • HAL Id : inria-00537449 , version 1
Alexis Angelidis. Sweepers & Swirling-sweepers. Eurographics tutorial, Aug 2005, Dublin, Ireland. pp.67--89. ⟨inria-00537449⟩
58 Consultations
110 Téléchargements
