Skeletal Reconstruction of Branching Shapes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1996
We present a new method for the implicit reconstruction of branching shapes from a set of scattered data points. The method is based on the computation of a geometric skeleton inside the data set. This skeleton is simplied in order to lter noise and converted into skeletal elements { a graph of interconnected curves { that generate an implicit surface. We use Bezier triangles as extra skeletal elements to perform bulge free blends between branches while controlling the blend extent. This leads to a smooth implicit representation of the shape, directly computed in a purely geometric way.
FCA-IS96.pdf (480.1 Ko) Télécharger le fichier
Format : Figure, Image
inria-00537532 , version 1 (18-11-2010)
  • HAL Id : inria-00537532 , version 1
Eric Ferley, Marie-Paule Cani, Dominique Attali. Skeletal Reconstruction of Branching Shapes. Implicit Surfaces, Oct 1996, Eindhoven, Netherlands. pp.127--142. ⟨inria-00537532⟩
1086 Consultations
353 Téléchargements
