Inverting the Reflectance Map with Binary Search - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Lecture Notes in Computer Science Année : 1995
Stereophotometric computer vision is based on the inversion of an equation system which represents the physical reflection phenomenon under different lighting conditions. In noisy conditions, the system has generally no solution, and the typical way to solve it is to find the solution which minimizes some error function. This paper proposes a new approach to deal with this system, using the so-called Geometrical Compatibility Function. The problem is turned into a root-finding in a one-dimensional space and the robustness is largely improved with respect to wrong reflectance model coefficients.
sfs.pdf (113.29 Ko) Télécharger le fichier
Format : Figure, Image
inria-00537544 , version 1 (18-11-2010)
  • HAL Id : inria-00537544 , version 1
François Faure. Inverting the Reflectance Map with Binary Search. Lecture Notes in Computer Science, 1995, 970, pp.814--819. ⟨inria-00537544⟩
88 Consultations
117 Téléchargements
