Continuation-Passing C: compiling threads to events through continuations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Higher-Order and Symbolic Computation Année : 2011
Juliusz Chroboczek
  • Fonction : Auteur
  • PersonId : 927254
In this paper, we introduce Continuation Passing C (CPC), a programming language for concurrent systems in which native and cooperative threads are unified and presented to the programmer as a single abstraction. The CPC compiler uses a compilation technique, based on the CPS transform, that yields efficient code and an extremely lightweight representation for contexts. We provide a proof of the correctness of our compilation scheme. We show in particular that lambda-lifting, a common compilation technique for functional languages, is also correct in an imperative language like C, under some conditions enforced by the CPC compiler. The current CPC compiler is mature enough to write substantial programs such as Hekate, a highly concurrent BitTorrent seeder. Our benchmark results show that CPC is as efficient, while using significantly less space, as the most efficient thread libraries available.
hosc-kerneis-chroboczek.pdf (343.94 Ko) Télécharger le fichier
inria-00537964 , version 1 (19-11-2010)
inria-00537964 , version 2 (14-02-2012)
inria-00537964 , version 3 (05-07-2012)
Gabriel Kerneis, Juliusz Chroboczek. Continuation-Passing C: compiling threads to events through continuations. Higher-Order and Symbolic Computation, 2011, 24 (3), pp.239-279. ⟨10.1007/s10990-012-9084-5⟩. ⟨inria-00537964v3⟩
178 Consultations
902 Téléchargements
