Unconditional self-modifying code elimination with dynamic compiler optimizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the issue of self-modifying code and packed programs, a long-standing problem commonly addressed by emulation techniques and memory dumps. We propose an original semantics-based approach to simplify dynamic code analysis, by using compiler optimization techniques to get rid of code-generating instructions. For this, we use classic slicing techniques to identify code dependencies. As it is semantics-based, our approach allows us to rely on strongly established formal methods and is a promising approach for handling packed programs.
packer.pdf (95.37 Ko) Télécharger le fichier
inria-00538376 , version 1 (22-11-2010)
  • HAL Id : inria-00538376 , version 1
Isabelle Gnaedig, Matthieu Kaczmarek, Daniel Reynaud, Stéphane Wloka. Unconditional self-modifying code elimination with dynamic compiler optimizations. 5th International Conference on Malicious and Unwanted Software, Fernando C. Colón Osorio, Oct 2010, Nancy, France. ⟨inria-00538376⟩
114 Consultations
662 Téléchargements
