Model-driven Architecture of a Maritime Surveillance System Simulator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems Engineering Année : 2010
This article reports on an experiment to apply a model-driven approach for systems engineering in an industrial context. This experiment consisted of setting up a model-driven simulation environment for a maritime surveillance system. The simulation is fully based on three models, each conforming to a specic metamodel. We discuss the main advances given by model-driven orientated simulation for systems engineering.
Monperrus09a.pdf (244.84 Ko) Télécharger le fichier
inria-00538455 , version 1 (22-11-2010)
Martin Monperrus, Benoit Long, Joël Champeau, Brigitte Hoeltzener, Gabriel Marchalot, et al.. Model-driven Architecture of a Maritime Surveillance System Simulator. Systems Engineering, 2010, 13 (3), pp.290-297. ⟨10.1002/sys.20149⟩. ⟨inria-00538455⟩
372 Consultations
441 Téléchargements
