Analysis and Verification of Service Interaction Protocols - A Brief Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Modeling and analysis of interactions among services is a crucial issue in Service-Oriented Computing. Composing Web services is a complicated task which requires techniques and tools to verify that the new system will behave correctly. In this paper, we first overview some formal models proposed in the literature to describe services. Second, we give a brief survey of verification techniques that can be used to analyse services and their interaction. Last, we focus on the realizability and conformance of choreographies.
salaun-TAVWEB2010.pdf (151.64 Ko) Télécharger le fichier
inria-00539017 , version 1 (23-11-2010)
  • HAL Id : inria-00539017 , version 1
Gwen Salaün. Analysis and Verification of Service Interaction Protocols - A Brief Survey. 4th International Workshop on Testing, Analysis and Verification of Web Software (TAV-WEB'10), Sep 2010, Antwerp, Belgium. pp.75-86. ⟨inria-00539017⟩
305 Consultations
154 Téléchargements
