Scheduling, Binding and Routing System for a Run-Time Reconfigurable Operator Based Multimedia Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a system for application scheduling, binding and routing for a run-time reconfigurable op- erator based multimedia architecture (ROMA). We use constraint programming to formalize our architecture model together with a specific application program. For this purpose we use an abstract representation of our architecture, which models memories, re- configurable operator cells and communication networks. We also model network topology. The use of constraints programming makes it possible to model the application scheduling, binding and routing as well as architectural and temporal constraints in a single model and solve it simultaneously. We have used several multimedia applications from the Mediabench set to evaluate our system. In 78% of cases, our system provides results that are proved optimal.
dasip2010.pdf (573.04 Ko) Télécharger le fichier
inria-00539874 , version 1 (25-11-2010)
  • HAL Id : inria-00539874 , version 1
Erwan Raffin, Christophe Wolinski, François Charot, Krzysztof Kuchcinski, Stéphane Guyetant, et al.. Scheduling, Binding and Routing System for a Run-Time Reconfigurable Operator Based Multimedia Architecture. Design and Architectures for Signal and Image (DASIP), Oct 2010, Edinburgh, United Kingdom. ⟨inria-00539874⟩
177 Consultations
346 Téléchargements
