Diagnosability verication with Petri net unfoldings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Knowledge-Based and Intelligent Engineering Systems Année : 2010
Complex systems increasingly require safety and robustness w.r.t. faults occurrences, and diagnosability is a key property to ensure this at design stage. This paper demonstrates how Petri net unfoldings, which have been proven to elevate the state explosion problem, can be applied to verify diagnosability by adapting the twin plant method.
KES-diagno-twin.pdf (274.62 Ko) Télécharger le fichier
inria-00540650 , version 1 (29-11-2010)
  • HAL Id : inria-00540650 , version 1
Agnes Madalinski, Farid Nouioua, Philippe Dague. Diagnosability verication with Petri net unfoldings. International Journal of Knowledge-Based and Intelligent Engineering Systems, 2010, 14 (2), pp.49-55. ⟨inria-00540650⟩
345 Consultations
176 Téléchargements
