Model Checking the Pastry Routing Protocol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pastry is an algorithm for implementing a scalable distributed hash table over an underlying P2P network, an active area of research in distributed systems. Several implementations of Pastry are available and have been applied in practice, but no attempt has so far been made to formally describe the algorithm or to verify its properties. Since Pastry combines rather complex data structures, asynchronous communication, concurrency, resilience to churn and fault tolerance, it makes an interesting target for verification. We have modeled Pastry's core routing algorithms in the specification language TLA+ and used its model checker TLC to analyze qualitative properties of Pastry such as correctness and consistency.
article-new.pdf (93.22 Ko) Télécharger le fichier
inria-00540811 , version 1 (29-11-2010)
  • HAL Id : inria-00540811 , version 1
Tianxiang Lu, Stephan Merz, Christoph Weidenbach. Model Checking the Pastry Routing Protocol. 10th International Workshop Automated Verification of Critical Systems, Sep 2010, Düsseldorf, Germany. pp.19-21. ⟨inria-00540811⟩
264 Consultations
423 Téléchargements
