The matched asymptotic expansion for the computation of the effective behavior of an elastic structure with a thin layer of holes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Multiscale Computational Engineering Année : 2011
In the framework of matched asymptotic expansions we introduce a new efficient and robust method to approximate the behavior of a structure con- taining a thin layer with periodically distributed micro-holes. A surface (in 3d) or a line in (2d) on which particular jumping conditions are defined sub- stitutes for the initial problem.
Fichier non déposé
inria-00540992 , version 1 (29-11-2010)
Giuseppe Geymonat, Sofiane Hendili, Françoise Krasucki, Marina Vidrascu. The matched asymptotic expansion for the computation of the effective behavior of an elastic structure with a thin layer of holes. International Journal for Multiscale Computational Engineering, 2011, 9 (5), pp.529-542. ⟨10.1615/IntJMultCompEng.v9.i5⟩. ⟨inria-00540992⟩
135 Consultations
0 Téléchargements
