Complex nonconvex lp norm minimization for underdetermined source separation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Underdetermined source separation methods often rely on the assumption that the time-frequency source coefficients are independent and Laplacian distributed. In this article, we extend these methods by assuming that these coefficients follow a generalized Gaussian prior with shape parameter p. We study mathematical and experimental properties of the resulting complex nonconvex lp norm optimization problem in a particular case and derive an efficient global optimization algorithm. We show that the best separation performance for three-source stereo convolutive speech mixtures is achieved for small p.
vincent_ICA07bis.pdf (123.4 Ko) Télécharger le fichier
inria-00544203 , version 1 (07-12-2010)
  • HAL Id : inria-00544203 , version 1
Emmanuel Vincent. Complex nonconvex lp norm minimization for underdetermined source separation. 7th Int. Conf. on Independent Component Analysis and Blind Source Separation (ICA), Sep 2007, London, United Kingdom. pp.430--437. ⟨inria-00544203⟩
325 Consultations
838 Téléchargements
