inria-00544230, version 1
Performance measurement in blind audio source separation
Emmanuel Vincent 1Rémi Gribonval
a, 2Cédric Févotte 3
IEEE Transactions on Audio, Speech, and Language Processing 14, 4 (2006) 1462--1469
Résumé : In this article, we discuss the evaluation of Blind Audio Source Separation (BASS) algorithms. Depending on the exact application, different distortions can be allowed between an estimated source and the wanted true source. We consider four different sets of such allowed distortions, from time-invariant gains to time-varying filters. In each case we decompose the estimated source into a true source part plus error terms corresponding to interferences, additive noise and algorithmic artifacts. Then we derive a global performance measure using an energy ratio, plus a separate performance measure for each error term. These measures are computed and discussed on the results of several BASS problems with various difficulty levels.
- a – INRIA
- 1 : Centre for Digital Music
- Queen Mary, University of London
- 2 : METISS (INRIA - IRISA)
- CNRS : UMR6074 – INRIA – INSA Rennes – Université de Rennes 1
- 3 : Department of Engineering [Cambridge]
- University of Cambridge
- Domaine : Informatique/Traitement du signal et de l'image
Sciences de l'ingénieur/Traitement du signal et de l'image
- inria-00544230, version 1
- http://hal.inria.fr/inria-00544230
- oai:hal.inria.fr:inria-00544230
- Contributeur : Emmanuel Vincent
- Soumis le : Mardi 7 Décembre 2010, 15:14:51
- Dernière modification le : Jeudi 9 Décembre 2010, 10:45:06
Documents associés
Voir aussi
Exporter
