Evaluation d'une nouvelle méthode de suivi de formants sur un corpus Arabe - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper develops a formant tracking technique based on Fourier ridges detection. In this method we have introduced a constraint of tracking based on the computation of centre of gravity for a set of frequency formant candidates which leads to connect a frame of speech to its neighbours and thus to improve the robustness of tracking. The formant trajectories obtained by the algorithm proposed are compared to those of a hand edited formant Arabic database, created especially for this work, and those given by Praat with LPC data.
papier_JEP_version_corrigA_e.pdf (317.19 Ko) Télécharger le fichier
inria-00544361 , version 1 (07-12-2010)
  • HAL Id : inria-00544361 , version 1
Imen Jemaa, Oussama Rekhis, Kais Ouni, Yves Laprie. Evaluation d'une nouvelle méthode de suivi de formants sur un corpus Arabe. XXVIIIèmes Journées d'Etude sur la Parole - JEP'10, May 2010, Mons, Belgique. ⟨inria-00544361⟩
219 Consultations
540 Téléchargements
