Physics-Based Spike-Guided Tools for Sound Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we present graphical tools and parameters search algorithms for the timbre space exploration and design of com- plex sounds generated by physical modeling synthesis. The tools are built around a sparse representation of sounds based on Gam- matone functions and provide the designer with both a graphical and an auditory insight. The auditory representation of a num- ber of reference sounds, located as landmarks in a 2D sound de- sign space, provides the designer with an effective aid to direct his search for new sounds. The sonic landmarks can either be syn- thetic sounds chosen by the user or be automatically derived by using clever parameter search and clustering algorithms. The pro- posed probabilistic method in this paper makes use of the sparse representations to model the distance between sparsely represented sounds. A subsequent optimization model minimizes those dis- tances to estimate the optimal parameters, which generate the land-mark sounds on the given auditory landscape.
SpikeGui_Dafx2010_2.pdf (339.53 Ko) Télécharger le fichier
inria-00545453 , version 1 (13-10-2011)
  • HAL Id : inria-00545453 , version 1
Kamil Adiloglu, Carlo Drioli, Pietro Polotti, Davide Rocchesso, Stefano Delle Monache. Physics-Based Spike-Guided Tools for Sound Design. Conference on Digital Audio Effects, Institute of Electronic Music and Acoustics, Sep 2010, Graz, Austria. ⟨inria-00545453⟩
122 Consultations
124 Téléchargements
