A Thin-plate CAD Mesh Model Splitting Approach Based on Fitting Primitives - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Extracting structural information from mesh models is crucial for Simulation Driven Design (SDD) in industrial applications. Focusing on thin-plate CAD mesh models (the most commonly used parts in electronic products such as PCs, mobile phones and so on), we present an algorithm based on primitive fitting for segmenting thin-plate CAD mesh models into parts of three different types, two of which are extruding surfaces and the other is a lateral surface. This method can be used for solid model reconstruction in the SDD process. Our approach involves two steps. First, a completely automatic method for accurate primitive fitting on CAD meshes is proposed based on the hierarchical primitive fitting framework. In the second step, a novel procedure is proposed for splitting thin-plate CAD mesh models by detecting parallel extruding surfaces and lateral surfaces. The method presented here has been proved to work smoothly in applications of real product design.
tpcg10-geng-fin.pdf (1.4 Mo) Télécharger le fichier
inria-00547799 , version 1 (17-12-2010)
Chun Geng, Hiromasa Suzuki, Dong-Ming Yan, Takashi Michikawa, Yuichi Sato, et al.. A Thin-plate CAD Mesh Model Splitting Approach Based on Fitting Primitives. EG UK Theory and Practice of Computer Graphics, University of Sheffield, Sep 2010, Sheffield, United Kingdom. pp.45-50, ⟨10.2312/LocalChapterEvents/TPCG/TPCG10/045-050⟩. ⟨inria-00547799⟩
214 Consultations
414 Téléchargements
