SecSIP User Documentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2010
This document is the user's guide of the SecSip software, a stateful SIP firewall. The report contains the installation guidelines, details the usage of the binaries delivered in the distribution, and explores the web-based manager interface that comes with it.
RT-0394.pdf (424.38 Ko) Télécharger le fichier
inria-00547831 , version 1 (27-12-2010)
  • HAL Id : inria-00547831 , version 1
Alexandre Boeglin, Abdelkader Lahmadi, Olivier Festor. SecSIP User Documentation. [Technical Report] RT-0394, INRIA. 2010, pp.25. ⟨inria-00547831⟩
95 Consultations
158 Téléchargements
