Bundle Adjustment -- A Modern Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
This paper is a survey of the theory and methods of photogrammetric bundle adjustment, aimed at potential implementors in the computer vision community. Bundle adjustment is the problem of refining a visual reconstruction to produce jointly optimal structure and viewing parameter estimates. Topics covered include: the choice of cost function and robustness; numerical optimization including sparse Newton methods, linearly convergent approximations, updating and recursive methods; gauge (datum) invariance; and quality control. The theory is developed for general robust cost functions rather than restricting attention to traditional nonlinear least squares.
Triggs-va99.pdf (586.75 Ko) Télécharger le fichier
Triggs-visalgs99-bundle-slides.pdf (373.24 Ko) Télécharger le fichier
Format : Autre
inria-00548290 , version 1 (20-12-2010)
Bill Triggs, Philip Mclauchlan, Richard Hartley, Andrew Fitzgibbon. Bundle Adjustment -- A Modern Synthesis. International Workshop on Vision Algorithms, Sep 2000, Corfu, Greece. pp.298--372, ⟨10.1007/3-540-44480-7_21⟩. ⟨inria-00548290⟩
8568 Consultations
14827 Téléchargements
