Bayesian Decision Versus Voting for Image Retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
Image retrieval from image databases is usually performed by using global image characteristics. However the use of local image information is highly desirable when only part of the image is of interest. An original solution was introduced in [9] using invariant local signal characteristics. This paper extends this contribution by extending the set of invariants considered to allow illumination change. Then it is shown that the invariant distribution is far from uniform and a probabilistic indexing scheme is proposed. Experimental results validate the approch and the different methods are discussed.
mohr97bayesian-1.pdf (949.21 Ko) Télécharger le fichier
inria-00548350 , version 1 (22-12-2010)
Roger Mohr, Sylvaine Picard, Cordelia Schmid. Bayesian Decision Versus Voting for Image Retrieval. 7th International Conference on Computer Analysis of Images and Patterns (CAIP '97), Sep 1997, Kiel, Germany. pp.376--383, ⟨10.1007/3-540-63460-6_140⟩. ⟨inria-00548350⟩
131 Consultations
215 Téléchargements
