Relative 3D Reconstruction Using Multiple Uncalibrated Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 1992
In this paper, we show how relative 3D reconstruction from multiple uncalibrated images can be achieved through reference points. The original contributions with respect to other related works in the field are mainly a direct non linear method for relative 3D reconstruction, a geometrical method to select the set of reference points among all image points and a geometrical interpretation of the linear reconstruction method. Experimental results from both simulated and real image sequences are presented.
relative_1.pdf (1.22 Mo) Télécharger le fichier
inria-00548434 , version 1 (31-05-2011)
  • HAL Id : inria-00548434 , version 1
Roger Mohr, Long Quan, Françoise Veillon, Boubakeur Boufama. Relative 3D Reconstruction Using Multiple Uncalibrated Images. [Technical Report] RT 84-IMAG- 12 LIFIA, 1992, pp.25. ⟨inria-00548434⟩
Collections
UGA LARA
105 Consultations
250 Téléchargements
