Accurate Object Localization with Shape Masks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper proposes an object class localization approach which goes beyond bounding boxes, as it also determines the outline of the object. Unlike most current localization methods, our approach does not require any hypothesis parameter space to be defined. Instead, it directly generates, evaluates and clusters shape masks. Thus, the presented framework produces much richer answers to the object class localization problem. For example, it easily learns and detects possible object viewpoints and articulations, which are often well characterized by the object outline. We evaluate the proposed approach on the challenging natural-scene Graz-02 object classes dataset. The results demonstrate the extended localization capabilities of our method.
MarszalekSchmid-CVPR07-ShapeMasks.pdf (1.78 Mo) Télécharger le fichier
MarszalekSchmid-CVPR07-ShapeMasks-slides.pdf (40.78 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00548679 , version 1 (20-12-2010)
Marcin Marszałek, Cordelia Schmid. Accurate Object Localization with Shape Masks. CVPR - IEEE Conference on Computer Vision & Pattern Recognition, Jun 2007, Minneapolis, United States. pp.1-8, ⟨10.1109/CVPR.2007.383085⟩. ⟨inria-00548679⟩
196 Consultations
712 Téléchargements
