Learning Distance Functions for Automatic Annotation of Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Josip Krapac
  • Fonction : Auteur
  • PersonId : 885309
Frédéric Jurie
This paper gives an overview of recent approaches towards image representation and image similarity computation for content-based image retrieval and automatic image annotation (category tagging). Additionaly, a new similarity function between an image and an object class is proposed. This similarity function combines various aspects of object class appearance through use of representative images of the class. Similarity to a representative image is determined by weighting local image similarities, where weights are learned from training image pairs, labeled "same" and "different", using linear SVM. The proposed approach is validated on a challenging dataset where it performed favorably.
kj07amr.pdf (2.38 Mo) Télécharger le fichier
inria-00548684 , version 1 (25-01-2011)
Josip Krapac, Frédéric Jurie. Learning Distance Functions for Automatic Annotation of Images. AMR - 5th International Workshop on Adaptive Multimedia Retrieval, Jul 2007, Paris, France. pp.1-16, ⟨10.1007/978-3-540-79860-6_1⟩. ⟨inria-00548684⟩
297 Consultations
165 Téléchargements
