Color feature detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2006
The detection and classification of local structures (i.e., edges, corners, an T-junctions) in color images is important for many applications, such as image segmentation, image matching, object recognition, and visual tracking in the fields of image processing and computer vision. In general, those local image structures are detected by differential operators that are commonly restricted to luminance information. However, most of the images recorded today are in color. Therefore, in this chapter, the focus is on the use of color information to detect and classify local image features.
CIP06.pdf (853.1 Ko) Télécharger le fichier
inria-00548685 , version 1 (24-01-2011)
Theo Gevers, Joost van de Weijer, Harro Stokman. Color feature detection. Rastislav Lukac and Konstantinos N. Plataniotis. Color image processing: methods and applications, 9, CRC press, pp.203-226, 2006, 978-0-8493-9774-5. ⟨10.1201/9781420009781⟩. ⟨inria-00548685⟩
768 Consultations
826 Téléchargements
