Wavelet denoising for P300 single-trial detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Laurent Bougrain
Template-based analysis techniques are good candidates to robustly detect transient temporal graphic elements (e.g. event-related potential, k-complex, sleep spindles, vertex waves, spikes) in noisy and multi-sources electro-encephalographic signals. More specifically, we present the impact on a large dataset of a wavelet denoising to detect evoked potentials in a single-trial P300 speller. Using coiflets as a denoising process allows to obtain more stable accurracies for all subjects.
Saavedra-NeuroComp10.pdf (588.33 Ko) Télécharger le fichier
inria-00549218 , version 1 (21-12-2010)
  • HAL Id : inria-00549218 , version 1
Carolina Saavedra, Laurent Bougrain. Wavelet denoising for P300 single-trial detection. Proccedings of the 5th french conference on computational neuroscience - Neurocomp'10, Oct 2010, Lyon, France. pp.227-231. ⟨inria-00549218⟩
206 Consultations
753 Téléchargements
