Contract Aware Components, 10 years after - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Proceedings in Theoretical Computer Science Année : 2010
The notion of contract aware components has been published roughly ten years ago and is now be- coming mainstream in several fields where the usage of software components is seen as critical. The goal of this paper is to survey domains such as Embedded Systems or Service Oriented Architecture where the notion of contract aware components has been influential. For each of these domains we briefly describe what has been done with this idea and we discuss the remaining challenges.
TenYearsAfter.pdf (194.36 Ko) Télécharger le fichier
inria-00554209 , version 1 (11-01-2011)
  • HAL Id : inria-00554209 , version 1
Antoine Beugnard, Jean-Marc Jézéquel, Noël Plouzeau. Contract Aware Components, 10 years after. Electronic Proceedings in Theoretical Computer Science, 2010, 37, pp.86-100. ⟨inria-00554209⟩
170 Consultations
244 Téléchargements
