Context-Oriented Programming: Beyond Layers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
While many software systems today have to be aware of the context in which they are executing, there is still little support for structuring a program with respect to context. A first step towards better context-orientation was the introduction of method layers. This paper proposes two additional language concepts, namely the implicit activation of method layers, and the introduction of dynamic variables
Loew07a-ICDL07-PyContext.pdf (109.16 Ko) Télécharger le fichier
inria-00555773 , version 1 (14-01-2011)
Martin von Löwis, Marcus Denker, Oscar Nierstrasz. Context-Oriented Programming: Beyond Layers. International Conference on Dynamic Languages (ICDL 2007), ESUG, 2007, Lugano, Switzerland. ⟨10.1145/1352678.1352688⟩. ⟨inria-00555773⟩
54 Consultations
257 Téléchargements
