Optimization Method for the Joint Allocation of Modulation Schemes, Coding Rates, Resource Blocks and Power in Self-Organizing LTE Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article investigates the problem of the allocation of modulation and coding, subcarriers and power to users in LTE. The proposed model achieves inter-cell interference mitigation through the dynamic and distributed self-organization of cells. Therefore, there is no need for any a prior frequency planning. Moreover, a two-level decomposition method able to find near optimal solutions is proposed to solve the optimization problem. Finally, simulation results show that compared to classic reuse schemes the proposed approach is able to pack more users into the same bandwidth, decreasing the probability of user outage.
infocom_2011_final.pdf (248.95 Ko) Télécharger le fichier
inria-00558007 , version 1 (20-01-2011)
  • HAL Id : inria-00558007 , version 1
David Lopez-Perez, Akos Ladanyi, Alpar Jüttner, Hervé Rivano, Jie Zhang. Optimization Method for the Joint Allocation of Modulation Schemes, Coding Rates, Resource Blocks and Power in Self-Organizing LTE Networks. 30th IEEE International Conference on Computer Communications (IEEE INFOCOM 2011) mini-conf, Apr 2011, Shanghai, China. ⟨inria-00558007⟩
349 Consultations
1133 Téléchargements
