DSM-PM2: A portable implementation platform for multithreaded DSM consistency protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Our work combines Java compilation to native code with a run-time library that executes Java threads in a distributed-memory environment with true parallelism. This approach is implemented within the Hyperion system for the distributed execution of compiled Java programs on clusters of PCs. To provide the illusion of a shared memory to Java threads, Hyperion has been built on top of DSM-PM2, a portable implementation platform for multithreaded distributed-shared-memory protocols. We have designed, implemented and experimented with two alternative consistency protocols compliant with the Java Memory Model. The protocols have different mechanisms for access detection: the first one uses explicit locality checks, whereas the second one is based on page faults. We illustrate the effects of the two access-detection techniques with five applications run on two clusters with different interconnection networks: BIP/Myrinet and SISCI/SCI.
Mots clés
hips01.pdf (167.1 Ko) Télécharger le fichier
inria-00563583 , version 1 (06-02-2011)
Gabriel Antoniu, Luc Bougé. DSM-PM2: A portable implementation platform for multithreaded DSM consistency protocols. Proc. 6th IEEE International Workshop on High-Level Parallel Programming Models and Supportive Environments (HIPS '01), Apr 2001, San Francisco, United States. pp.55-70, ⟨10.1109/IPDPS.2001.925077⟩. ⟨inria-00563583⟩
76 Consultations
302 Téléchargements
