Towards Distributed Process Networks with CORBA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Parallel and Distributed Computing Practices Année : 2002
Process networks is a widely used model to describe highly concurrent applications. We present here a distributed implementation of a slightly restricted process network model realized using the CORBA middleware. This implementation allows the non computer science specialist to easily program heterogeneous meta-applications based on an assembly of components communicating through FIFO queues.
Fichier non déposé
inria-00565180 , version 1 (11-02-2011)
  • HAL Id : inria-00565180 , version 1
Abdelkader Amar, Pierre Boulet, Jean-Luc Dekeyser. Towards Distributed Process Networks with CORBA. Parallel and Distributed Computing Practices, 2002, 5 (4). ⟨inria-00565180⟩
82 Consultations
0 Téléchargements
