Une approche à la SQL du traitement de données intensif dans Gaspard
The Gaspard (Graphical Array Specification for PARallel and Distributed computing) project is a visual specification environment for data-parallelism. We describe here the specification model used in Gaspard. This model inherits from the Array-OL one. We then define an SQL inspired approach to intensive data treatment that proposes a language to describe irregular components.
