Comparative Study of Gaussian Dispersion Formulas within the Polyphemus Platform: Evaluation with Prairie Grass and Kincaid Experiments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Meteorology and Climatology Année : 2009
This paper details a number of existing formulations used in Gaussian models in a clear and usable way, and provides a comparison within a single framework—the Gaussian plume and puff models of the air quality modeling system Polyphemus. The emphasis is made on the comparison between 1) the parameterizations to compute the standard deviations and 2) the plume rise schemes. The Gaussian formulas are first described and theoretically compared. Their evaluation is then ensured by comparison with the observations as well as with several well-known Gaussian and computational fluid dynamics model performances. The model results compare well to the other Gaussian models for two of the three parameterizations for standard deviations, Briggs's and similarity theory, while Doury's shows a tendency to underestimate the concentrations because of a large horizontal spread. The results with the Kincaid experiment point out the sensitivity to the plume rise scheme and the importance of an accurate modeling of the plume interactions with the inversion layer. Using three parameterizations for the standard deviations and the same number of plume rise schemes, the authors were able to highlight a large variability in the model outputs.
korsakissok09comparative.pdf (567.16 Ko) Télécharger le fichier
inria-00566228 , version 1 (04-03-2011)
Irène Korsakissok, Vivien Mallet. Comparative Study of Gaussian Dispersion Formulas within the Polyphemus Platform: Evaluation with Prairie Grass and Kincaid Experiments. Journal of Applied Meteorology and Climatology, 2009, 48 (12), pp.2459--2473. ⟨10.1175/2009JAMC2160.1⟩. ⟨inria-00566228⟩
156 Consultations
2002 Téléchargements
