Robustness and the Halting Problem for Multi-Cellular Artificial Ontogeny - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Evolutionary Computation Année : 2011
Most works in Multi-Cellular Artificial Ontogeny solve the halting problem by arbitrarily limiting the number of iterations of the developmental process. Hence, the trajectory of the developing organism in the phenotypic space is only required to come close to an accurate solution during a very short developmental period. Because of the well-known opportunism of evolution, there is indeed no reason for the organism to remain close to a good solution in other situations: if the development is continued after the limiting bound; if the environment is perturbed by some noise during the development; if the development takes place in different physical conditions. In order to increase the robustness of the solution against such hazards, a new stopping criterion for the developmental process is proposed, based on the stability of some internal energy of the organism during its development. Such adaptive stopping criterion biases evolution toward solutions in which robustness is an intrinsic property. Experimental results on different ''French flag'' problems demonstrate that enforcing stable developmental process makes it possible to produce solutions that not only accurately approximate the target shape, but also demonstrate near-perfect self-healing properties, as well as excellent generalization capabilities.
embryo.pdf (603.43 Ko) Télécharger le fichier
inria-00566879 , version 1 (17-02-2011)
  • HAL Id : inria-00566879 , version 1
Alexandre Devert, Nicolas Bredeche, Marc Schoenauer. Robustness and the Halting Problem for Multi-Cellular Artificial Ontogeny. IEEE Transactions on Evolutionary Computation, 2011. ⟨inria-00566879⟩
98 Consultations
574 Téléchargements
