Characterizing and approximating eigenvalue sets of symmetric interval matrices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
We consider the eigenvalue problem for the case where the input matrix is symmetric and its entries perturb in some given intervals. We present a characterization of some of the exact boundary points, which allows us to introduce an inner approximation algorithm, that in many case estimates exact bounds. To our knowledge, this is the first algorithm that is able to guaran- tee exactness. We illustrate our approach by several examples and numerical experiments.
RR-7544.pdf (272.16 Ko) Télécharger le fichier
inria-00567385 , version 1 (21-02-2011)
  • HAL Id : inria-00567385 , version 1
  • ARXIV : 1102.4180
Milan Hladik, David Daney, Elias Tsigaridas. Characterizing and approximating eigenvalue sets of symmetric interval matrices. [Research Report] RR-7544, INRIA. 2011, pp.22. ⟨inria-00567385⟩
149 Consultations
309 Téléchargements
