DVB-T2 Simulation Model for OPNET - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
DVB-T2 is offering a new way for broadcasting value-added services to end users, such as High Denition (HD) TV and 3D TV. Thanks to the advances made in digital signal processing, and specically in channel coding, DVB- T2 brings an increased transfer capacity of 50% and a new exibility in services' broadcasting in contrast with the rst generation DVB-T standard. As DVB-T2 is still in deployment's test, simulation model could be an interesting way to evaluate the performance of this network in supporting new value-added services. In this paper, we describe the new features and enhancements we have integrated within the DVB-T2 module in OPNET, and in particular: (i) a realistic physical model;(ii) an MPEG-TS layer with an IP encapsulator;(iii) hierarchical application layer ables to use pcap traces to simulate real video traces. Also, we include an extensive simulation campaign in order to well understand the performance of DVB-T2 networks.
PI-1967.pdf (2.49 Mo) Télécharger le fichier
inria-00567546 , version 1 (21-02-2011)
  • HAL Id : inria-00567546 , version 1
Adlen Ksentini, Yassine Hadjadj-Aoul. DVB-T2 Simulation Model for OPNET. [Research Report] PI 1967, 2011, pp.17. ⟨inria-00567546⟩
430 Consultations
811 Téléchargements
