Transparent Parallelization of Binary Code - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper describes a system that applies automatic parallelization techniques to binary code. The system works by raising raw executable code to an intermediate representation that exhibits all memory accesses and relevant register definitions, but outlines detailed computations that are not relevant for parallelization. It then uses an off-the-shelf polyhedral parallelizer, first applying appropriate enabling transformations if necessary. The last phase lowers the internal representation into a new executable fragment, re-injecting low-level instructions into the transformed code. The system is shown to leverage the power of polyhedral parallelization techniques in the absence of source code, with performance approaching those of source-to-source tools.
paper.pdf (106.48 Ko) Télécharger le fichier
inria-00572797 , version 1 (28-07-2011)
  • HAL Id : inria-00572797 , version 1
Benoit Pradelle, Alain Ketterlin, Philippe Clauss. Transparent Parallelization of Binary Code. First International Workshop on Polyhedral Compilation Techniques, IMPACT 2011, in conjunction with CGO 2011, Christophe Alias, Cédric Bastoul, Apr 2011, Chamonix, France. ⟨inria-00572797⟩
Collections
CNRS INRIA INRIA2
211 Consultations
120 Téléchargements
