Harmonic Decomposition of Audio Signals with Matching Pursuit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Signal Processing Année : 2003
We introduce a dictionary of elementary waveforms, called harmonic atoms, that extends the Gabor dictionary and fits well the natural harmonic structures of audio signals. By modifying the "standard" matching pursuit, we define a new pursuit along with a fast algorithm, namely, the fast harmonic matching pursuit, to approximate N-dimensional audio signals with a linear combination of M harmonic atoms. Our algorithm has a computational complexity of O(MKN), where K is the number of partials in a given harmonic atom. The decomposition method is demonstrated on musical recordings, and we describe a simple note detection algorithm that shows how one could use a harmonic matching pursuit to detect notes even in difficult situations, e.g., very different note durations, lots of reverberation, and overlapping notes.
2003_IEEE_TSP_GribonvalBacry_HarmonicMP.pdf (1.91 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00576203 , version 1 (13-03-2011)
Rémi Gribonval, Emmanuel Bacry. Harmonic Decomposition of Audio Signals with Matching Pursuit. IEEE Transactions on Signal Processing, 2003, 51 (1), pp.101--111. ⟨10.1109/TSP.2002.806592⟩. ⟨inria-00576203⟩
408 Consultations
714 Téléchargements
