Looking for Efficient Implementations of Concurrent Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
As introduced by Taubenfeld, a contention-sensitive implementation of a concurrent object is an implementation such that the overhead introduced by locking is eliminated in the common cases, i.e., when there is no contention or when the operations accessing concurrently the object are non-interfering. This paper, that can be considered as an introductory paper to this topic, presents a methodological construction of a contention-sensitive implementation of a concurrent stack. In a contention-free context a push or pop operation does not rest on a lock mechanism and needs only six accesses to the shared memory. In case of concurrency a single lock is required. Moreover, the implementation is starvation-free (any operation is eventually executed). The paper, that presents the algorithms in an incremental way, visits also a family of liveness conditions and important concurrency-related concepts such as the notion of an abortable object.
PI-1969.pdf (451.64 Ko) Télécharger le fichier
inria-00576742 , version 1 (15-03-2011)
  • HAL Id : inria-00576742 , version 1
Achour Mostefaoui, Michel Raynal. Looking for Efficient Implementations of Concurrent Objects. [Research Report] PI-1969, 2011, pp.10. ⟨inria-00576742⟩
184 Consultations
191 Téléchargements
