Modular Graph Rewriting to Compute Semantics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bruno Guillaume
Mathieu Morey
Guy Perrier
  • Fonction : Auteur
  • PersonId : 8101
  • IdHAL : guy-perrier
Taking an asynchronous perspective on the syntax-semantics interface, we propose to use modular graph rewriting systems as the model of computation. We formally define them and demonstrate their use with a set of modules which produce underspecified semantic representations from a syntactic dependency graph. We experimentally validate this approach on a set of sentences. The results open the way for the production of underspecified semantic dependency structures from corpora annotated with syntactic dependencies and, more generally, for a broader use of modular rewriting systems for computational linguistics.
Mots clés
iwcs.pdf (201.36 Ko) Télécharger le fichier
inria-00579244 , version 1 (24-03-2011)
  • HAL Id : inria-00579244 , version 1
Guillaume Bonfante, Bruno Guillaume, Mathieu Morey, Guy Perrier. Modular Graph Rewriting to Compute Semantics. 9th International Conference on Computational Semantics - IWCS 2011, Jan 2011, Oxford, United Kingdom. pp.65--74. ⟨inria-00579244⟩
234 Consultations
156 Téléchargements
