Extended Dependency Tree-HMM for Non-Rectangular Sub-Images Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Abdel Belaïd
  • Fonction : Auteur
  • PersonId : 830137
This work is motivated by the need of evaluating the likelihood probability on sub-images of not necessarily rectangular shape in some frameworks. For this purpose, we propose an alternative of Dependency Tree- HMM that allows the four traditional interactions between neighboring pixels instead of just two. To demonstrate the accuracy of the proposed model, we provide some classification results performed on high resolution aerial images.
Extended_DT-HMM_for_Sub-Images_Modeling.pdf (139.13 Ko) Télécharger le fichier
inria-00579675 , version 1 (24-03-2011)
  • HAL Id : inria-00579675 , version 1
Mohamed El Yazid Boudaren, Abdel Belaïd. Extended Dependency Tree-HMM for Non-Rectangular Sub-Images Modeling. The Fifth International Workshop on Applied Probability - IWAP 2010, Universidad Carlos III de Madrid, Jul 2010, Madrid, Spain. pp.4. ⟨inria-00579675⟩
73 Consultations
52 Téléchargements
