Decomposition of a curve into arcs and line segments based on dominant point detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new solution is proposed to decompose a curve into arcs and straight line segments in $O(n\log n)$ time. It is a combined solution based on arc detection \cite{Nguyen10a_} and dominant point detection \cite{Nguyen10f} to strengthen the quality of the segmentation results. Experimental results show the fastness of the proposed method.
ArcDecomposition_scia.pdf (447.33 Ko) Télécharger le fichier
inria-00580123 , version 1 (26-03-2011)
  • HAL Id : inria-00580123 , version 1
Thanh Phuong Nguyen, Isabelle Debled-Rennesson. Decomposition of a curve into arcs and line segments based on dominant point detection. Scandinavian Conference on Image Analysis - SCIA 2011, May 2011, Ystad Saltsjöbad, Sweden. ⟨inria-00580123⟩
375 Consultations
5300 Téléchargements
