s'authentifier
version française rss feed
inria-00582457, version 1
Node coloring for dense wireless sensor networks
Ichrak Amdouni () a1, Pascale Minet () 1, Cédric Adjih () a1
N° RR-7588 (2011)
Résumé : Coloring is used in wireless networks to improve communication efficiency, mainly in terms of bandwidth, energy and possibly end-to-end delays. In this research report, we define the h-hop node coloring problem, with h any positive integer. We prove that the associated decision problem is NP-complete. We then present a 3-hop distributed coloring algorithm that is optimized for dense networks: a node does not need to exchange the priorities and colors of its 2-hop neighbors. Through simulation results, we highlight the impact of priority assignment on the number of colors obtained for any network. We then focus on grids and identify a color pattern that can be reproduced to color the whole grid. We show how the coloring algorithm can use regularity properties to obtain a periodic color pattern with the optimal number of colors. We then consider grids with holes and study how to extend our results.
  • Domaine : Informatique/Réseaux et télécommunications
  • Mots-clés : coloriage de graphe – réseaux de capteurs sans fil – MANET – réseaux mobiles ad hoc – efficacité énergétique – réutilisation spatiale – grille – NP-complet – complexité – réseaux denses – motif
  • Référence interne : RR-7588
  • inria-00582457, version 1
  • oai:hal.inria.fr:inria-00582457
  • Contributeur :
  • Soumis le : Vendredi 8 Avril 2011, 17:55:12
  • Dernière modification le : Lundi 11 Avril 2011, 09:31:11
tous les articles de la base du CCSd...
