A Continuous Time Approach for the Asymptotic Value in Two-Person Zero-Sum Repeated Games
1 Introduction: Shapley 2 Extensions of the Shapley operator : general repeated games 3 Extensions of the Shapley operator : general evaluation 4 Asymptotic analysis: the main results 5 Asymptotic analysis - the discounted case: games with incomplete information 6 Asymptotic analysis - the continuous approach: games with incomplete information 7 Asymptotic analysis - the continuous approach: extensions
Optimisation et contrôle [math.OC]
