Random Cross Ratios - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 1992
Random Cross Ratios
The main result of this paper is the derivation of the probability density function of the cross ratio k(a,b,c,d)=(c-a)(d-b)/(d-a)(c-b) when the numbers a, b, c and d are independent stoch astic variables with identical rectangular distribution. The probability density function of the cross ratio is needed to study the effectiveness of invariant based recognition systems. A short background into invariant based recognition is given. The use of the result is illustrated by examples and a short comment is given on generalizing the result to other distributions on a, b, c and d. Although theoretical, this result is useful in understanding algorithms based on the cross ratio, e.g. in autonomous vehicle navigation, object recognition and reconstruction from images.
10.1.1.139.8226.pdf (93.96 Ko) Télécharger le fichier
inria-00590012 , version 1 (03-05-2011)
  • HAL Id : inria-00590012 , version 1
Kale Aastrom, Luce Morin. Random Cross Ratios. [Technical Report] IMAG-RT - 92-088 ; LIFIA - 92-014, 1992, pp.8. ⟨inria-00590012⟩
195 Consultations
164 Téléchargements
